Subject: Re: CABINET VISION CUSTOM MACHINING
3/16/21
Ben Member
Hello, I wondered if it was possible to link machining operations with different scenarios of cabinet internals in cabinet vision so that I do not have to manually edit the machining operation. For example, for every fixed shelf that is set back from the front of the carcass, I require the machining (Dado-master) to stop 6mm short of the shelf depth. Any help would be greatly appreciated, thanks.
3/16/21       #2: CABINET VISION CUSTOM MACHINING ...
Jared Member
I'm reasonably sure a UCS could be written to address this condition. For every Fixed Shelf that equals Case Depth minus a certain amount, make this operation equal the Fixed Shelf width minus a certain amount.
Now how to write that UCS is a different story. If you don't have the time to learn it, you could get the Vero people to write it for you.
3/17/21       #4: CABINET VISION CUSTOM MACHINING ...
Ben Member
Yeah thank you I thought it would have to be something in the user created standards.. not fully got into how exactly it would work but I will definitely give it a good go! Any further help would be greatly appreciated
    • Limtech Industries, Inc.
    • Template Services
    • Biesse America
