Subject: Re: NC HOPS C axis posting incorrectly
4/16/21
Ian
Hello, I am trying to sort out an issue with a common type of program thst we use, but this one in particular is stubborn. I have been on the horn with Alphacam and Holzher, but meither can seem to dolve the issue. I am trying to swing a 60 degree vertical arc on a handrail upeasing. We have done this numerous times with no issues. I am uding a solid model created in Rhino, exported as a DWG, imported into Alphacam, and exported as HOPS 6 file. I am using machine spline/ polyline ,- tool directions are correct, and global coordinates are also correct. Im referencing a parallel face on the model in regard to the tool. When i run the program, the C axis rotates 180 degrees, which it should not fo, only swing in A axis and corresponding X/ Y movements.
If you are seeing this message, your version of flash needs to be upgraded to view this video.
Click here to get the latest version of the Flash player.
4/16/21       #3: NC HOPS C axis posting incorrectly ...
Ian
Sorry about the spelling errors, posted from phone with tiny letters
6/16/21       #4: NC HOPS C axis posting incorrectly ...
Marek  Member
Website: http://www.cadcam-softcz.cz
Hello,
can you please send me your *.hop file to my email?
m.skotak@cadcam-softcz.cz
    • Biesse America
