Subject: Re: New cnc, router bit help
8/3/21
Daniel Member
I just received my first cnc 4'x9'. I plan to use dados for my construction method. I build face frame cabinets.
I want to pre-drill through the dados for #8 screws. I'm thinking I'll glue and brad nail or staple the decks, partitions, fixed shelves and tops. Then drive a few #8 screws. Applied doors or skins will cover the screws on finished ends.
My question is if I pre-drill the cabinet sides through the dados, what bit do I use?
Do I use a 1/8" drill bit or upcut or down cut or compression?
I do have a couple 1/8" collets for my machine but am lost when it comes to knowing which bit to use.
Thanks for the help.
8/3/21       #2: New cnc, router bit help ...
Mark B
We do all our pre-drilling with the same 5mm brad point as shelf pin holes. 1/2" shank or 10mm shank.
8/3/21       #3: New cnc, router bit help ...
Daniel Member
What size screw you use with 5mm pre-drill?
8/3/21       #4: New cnc, router bit help ...
If you are drilling with your spindle, put a drill bit in the collet and slow the rpm's and drill the hole.
8/3/21       #5: New cnc, router bit help ...
Daniel Member
What rpm would you run a 1/8” drill bit ?
8/3/21       #6: New cnc, router bit help ...
Mark B
All the tools are in the tool changer. We run 5mm brad point at 8k with a 200ipm plunge. You can find your tool and drill feeds and speed numerous places. I often refer to a handy app on android FSwizard if Im worried about critical feeds/speeds.
We run a standard screw with nibs in a 5mm hole so we dont have to countersink (all drilling is from the inside).
8/3/21       #7: New cnc, router bit help ...
Daniel Member
Great, thanks for the info.
8/3/21       #8: New cnc, router bit help ...
Kris
For our #8 pilot holes we use a 4mm V point dowel drill bit.
(we also have drill blocks, so we don't have to worry about tool change time, or space limitations)
8/4/21       #9: New cnc, router bit help ...
With standard drills in the spindle, I typically just match the rotation speed on our drill block with is 6,000 RPM. I usually only drill with the spindle when the diameter is an odd size or the plunge depth is more than I can get with the drill block. Horse power drops off pretty hard with reduced spindle speed, but with drilling, it shouldn't be an issue.
8/4/21       #10: New cnc, router bit help ...
Mark B
I dont drill with a v point because with the brad point and .045 over drill Im just left with the slightest peck and ring in the spoil board from the brad point and the knickers. It leaves a paper thin disk in the hole on the back side so you can see your screw location but were not left with deep over-drill holes in the spoilboard. No drill block but 4mm for handles, and 5mm for shelf pins are in the changer. The 5mm works better for me with nibbed screws being a touch oversize and sinking them flush.
    • Machinery Associates
    • Country Saw and Knife
