Subject: Re: Best 1/2" router bit for 3" mortise
8/12/21
Chad Lueken
We are running mortises on the CNC, trying to a get 3" depth. It seems like it puts a lot a pressure on the tool when it reaches the end of the mortise. We are looking for better tooling to handle this operation. We are currently running 1/2" rougher, 3 flute, upcut, 1/8" depth per pass at 80 inches per minute. Takes 30 passes to make s mortise.
8/12/21       #2: Best 1/2" router bit for 3&quo ...
rich c
I'd suggest you use a pecking drill program to drill out the waste, then do a cleanup. Older manual spindle mortising machines used a birds mouth bit to do deep, but they are hard to find. I've never used these, but maybe worth a try.
https://www.toolstoday.com/v-9783-45540.html
8/13/21       #3: Best 1/2" router bit for 3&quo ...
Mark B
That tool rich posted is what I run when doing deep mortises in solids and I to a spiral down pocketing operation that hogs the material out from the center if I have to do it all on the cnc. Long tools with full engagement havent worked for me and as your speeds show they have to run so painfully slow its no fun.
It may not be an option that you care for but the what I do is setup an initial toolpath that defines the mortise at .100" deep then I take a right angle drill or hole hawg with the a self-feed that leaves 1/4" per side or so and hog the bulk of the material out with the drill. Then I have a second pocket toolpath that just goes in an wastes away the material the self-feed couldnt get.
Its way faster and less wear and tear on my machine than trying to pocket away all that material.
8/13/21       #4: Best 1/2" router bit for 3&quo ...
We can take our bit say 2" CL and do a spin down on the other 1" to keep from rubbing and actually have a better bit
8/13/21       #5: Best 1/2" router bit for 3&quo ...
Mark B
What does necking down a tool cost compared to a $58 bit? Im well aware that tool as its being mentioned is an off-label use and not defending amana in any way but thats a hard number to beat if your smart using it. One mishap and you'll more than likely wipe out your spindle....
8/13/21       #6: Best 1/2" router bit for 3&quo ...
usually around $20 if you are talking 1-3 pcs
