Subject: Re: Flexible dust hose, how long do they last?
9/2/21
Matt
The past few years I've noticed that flexible dust hoses hardly last anymore. On both my edgebander and CNC I'm getting maybe 2 years before they start splitting.....even on hoses that are connected to nonmoving ports.
Our CNC is hardly 2 years old and there's a lot of splits.
We route mostly plywood and melamine, and I know the melamine can be abrasive, but this seems to be getting ridiculous.
These are the expensive copper-coiled static dissipative hoses, I'm pretty sure the CNC came with Urethane hoses.
For longevity, what should I be buying?
9/2/21       #2: Flexible dust hose, how long do the ...
I amusing neoprene coated nylon fabric hoses now. So far, so good. I attached a link. The link I attached is for 12", but I think other sizes are available. Some hoses last, others are junk.
https://hosewarehouse.com/products/flexaust-cwy-12-inch-material-handling-duct-hose-25ft
9/3/21       #3: Flexible dust hose, how long do the ...
Bill Stanisci Member
One of our CNC hoses is 10 years old. It is the quality of hose you are using.
We get ours from American Blower in Michigan. I explain the function and they recommend the hose. We have had good luck.
I do have one spot where our main collector connects to the dust dumpster that seem to eat hoses. That is our only hose issue.
9/5/21       #4: Flexible dust hose, how long do the ...
Jon Member
We get hose from Wynn Environmental. 30 Mil clear urethane. Holds up well on router/saws/planer etc.
9/10/21       #5: Flexible dust hose, how long do the ...
Robert Duff  Member
Website: http://www.abettercloset.net
Do you have a ball joint at the top? Is the center of the hose supported?
9/13/21       #6: Flexible dust hose, how long do the ...
JKL Machinery  Member
Website: http://www.jklmachinery.com
Flexhaust FlexThan LD is best, we provide with every CNC machine we install.
This flex hose collapses on itself but does not flatten. Will not interfere with axis drives.
1/23/24       #7: Flexible dust hose, how long do the ...
Kevin Mackwell
Hi all,
I'm finding the same problem for our Biesse.
The 6" OEM hoses are ridiculously expensive but all the aftermarket hose is too thick and won't allow full travel on the head.
I need a thin gauge wall that will fold over on itself.
Any suggestions in Canada?
