Subject: Re: pendulum production software
9/15/21
Bryan Member
Just purchased a 8’x20’ multicam 3000 router. Want to run it in pendulum method using four 4’x8’ panels and side load them. Any idea on software to run a process like that? Or an add on to an existing cabinet design program.
9/18/21       #2: pendulum production software ...
Jim Anderson
Bryan,
Pendulum processing is not a software issue. While you are running a program on spoilboard 1 (or Home 1), you are loading and unloading on spoilboard 2 (or Home 2). On some older MultiCams, there was a physical switch to go between the pre-programmed homes, otherwise your operator only needs to switch between Home 1 and Home 2 to make it work properly. If your machine is not setup for pendulum processing, and you are set to park at the end of your programs instead of going to 0,0, you risk someone being injured by the gantry moving in rapid motion while they are loading and unloading. If you set the park position to be between the 2 home positions, you should be relatively safe.
9/20/21       #3: pendulum production software ...
Ian Giudilli
Our Holzher is a pendulum processing machine, but has a safety mat to monitor the operator working in zones.
    • Limtech Industries, Inc.
