Subject: Re: Mdf recess panel doors
10/3/21
Jonathan Mahnken
Just made my first small set of mdf doors using weiyerhauser(sp?) mdf. They made me a little nervous, it was hard to keep them flat during painting. I have heard that some of you are cutting a relief on the back side. What does this look like? I use mlc agualente wb primer. should I be using some sort of waterproof mdf?
10/5/21       #2: Mdf recess panel doors ...
Richard
Hi Johnathan,
Cutting a recess in the back does help with reducing warping and I have worked in shops where that's done. However it does significantly increase your CNC time. Plus you will need to to have software that can efficiently produce that extra recess in the back.
I am not sure about the finish you are ising as that's not really an area I've never dealt with but in general I wouldn't recommend waterproof MDF for shaker doors. It doesn't machine as smoothly and requires a lot more prep before finishing.
Hopefully this helps.
Richard
10/6/21       #3: Mdf recess panel doors ...
Robert
In my somewhat limited experience (simply try to avoid MDF all together!!)….when I CNC MDF must (4 customer satisfaction / cost reasons), to help keeping them “flat”, I’ve found best results with this way :
Get best MDF grade money & local dist can offer (ie : Plum Creek mdf!)
When finishing, use …what is known as push-pull coating = Meaning, use more coats on the push side ( say for shaker, the back side, it gets 3 more coats 1st, let dry, before applying additional face / back coats)…..yes = more finishing cost, but….also = much better results….out of this darn MDF !
My 2ct practice advise !
Good luck, Robert
11/4/21       #4: Mdf recess panel doors ...
Chris
We’ve had great luck with melamine backed ranger platinum MDF. Stays flat and saves us 1 primer coat on the back.
Are the doors warping before finish or after? If after maybe a solvent based product would help.
11/12/21       #5: Mdf recess panel doors ...
Jonathan Mahnken
Thanks Chris. is the melamine backed mdf a common thing or is this done for you by a local lumber company?
11/12/21       #6: Mdf recess panel doors ...
Robert Masso
Johnathan, melamine backer MDF is "quite" common among mat. distributors, ask your local supplier.
"great for CNC-ing, as "more precise" surface machining holding (less warping or say, bowing) when machining, regardless of hold downs, ( mechanic or vacuum, as I have, will not hold "properly" (say against bowing) as it as a difficult to hold cause by suction going through machined MDF !!
MY 2ct, ...
Ya, I'll second as for it's a common use to "cure" or say at least minimize this warping effect.
my "peev" with it, you still have to work "say a lot" to prep it since, over-spray from spraying sides will inevitable produce over-spray on this melamine backer.
Few solutions, sure ( Ie, tape & paper, ruff sand before and spay surface too....etc)....my point, it's extra cost (the material part + labor part) & extra time anyway....over 20yr in this trade, my take....much, much more efficiency by simply spray regular backer a few time before, as suggested in my previous post....
Again, in respect to any other opinion ( respectful or debatable!?!)....it's my way of doing a cheaper and yet, yield a best to better result "for me" !
All the best, good luck
    • Machinery Associates
    • Country Saw and Knife
