Subject: Re: cnc router nesting software
11/5/21
JT Member
Hi Everyone, Is there a nesting software out there that is reasonably priced that will import and sort AutoCad 3d solid models. Many years ago I used Sigmanest that had that capability, it could import entire assemblies from AutocCad or Solid Works and it organized the sheets by material thickness and nested them. is there a product like that out there that doesn't cost so much.
11/8/21       #2: cnc router nesting software ...
AcctekChina Member
What is your price budget?
11/10/21       #3: cnc router nesting software ...
Dan
The solution we use is from Cim-Tech. The cost is not inexpensive, but the product is good. We use the Solid-Cim product to export 3d parts from AutoCad or inventor and then process using Router-Cim in AutoCad. Solid-Cim will also work with Solid Works.
You can find more information at www.cim-tech.com.
Good luck in your search.
    • Template Services
    • Charles G.G. Schmidt Co.
