Subject: Re: Axis 349 interpolation not completed offset tension axisy excessive
11/18/21
John Earp
Biesse Rover 24. What does this mean?
11/18/21       #2: Axis 349 interpolation not complete ...
Not knowing Biesse controllers, a good guess would be the lead in to turn on cutter compensation was not long enough to turn it on. Many controllers need a movement at a minimum of the amount being compensated. Don't know what Biesse uses, but that is my stab in the dark. Good luck with that. If you were doing a hole slightly bigger than the tool, then I would definitely lean toward my guess.
11/18/21       #3: Axis 349 interpolation not complete ...
John Earp
Thanks for your reply. It was not so complicated. I shut the Biesse off for a
few minutes then rebooted and all was
well again! The computer in the office
had blinked off yesterday. i think an electrical gremlin hit them both.
Thanks again, John
    • Template Services
