Subject: Re: Carbide tip drilling
12/7/21
big money
Does anyone have any experience drilling hardwood with carbide tipped drills? Running a Rover A.
I'm not getting much life out of these drills, they are burning out very quickly.
Im running around 12000 rpm feedrate about 200 .5 peck
I feel like i should crank the rpm way down but Im not sure what a good baseline is with carbide drills in wood.
12/7/21       #2: Carbide tip drilling ...
duster
I run my 5 mm drills @ 5000 rpm. Never had one break or burn.
12/8/21       #3: Carbide tip drilling ...
Acctek  Member
The linear speed of hard alloy drills for processing low and medium carbon steel is 60~120m/min, with a large range. The specific speed depends on whether your tool is coated or not
12/8/21       #4: Carbide tip drilling ...
Bill Member
12,000 is too high. Call the drill bit manufacturer to get a good starting point.
12/8/21       #5: Carbide tip drilling ...
Mark B
What diameter drill? Regardless I would agree on the RPM being way too high. Small diameters Im in the same range as duster. 6000rpm with a 300ipm plunge
12/8/21       #6: Carbide tip drilling ...
Chuck Hicks
What is the diameter of the bit? most are running 3000 to 5000 RPM. Bigger diameters are even slower.
12/8/21       #7: Carbide tip drilling ...
big money
Its 13mm diameter, no coating
I slowed the rpms down to around 4500-5000 rpm with 200ipm feed and its much better although i can feel some resistance when trying to push the feed more than that
I'll try bringing it down to the 3k range, if @duster you run a 5mm at 5k
I'm also using about a 3/8 peck, I think I should be able to increase the peck depth though, all that going in and out creates more heat right?
thanks for the responses btw
12/11/21       #8: Carbide tip drilling ...
Quality of drill makes a big difference too. What brand are you using? Usually higher quality means a better grind on the drill. You are using a brad point style aren't you?
    • Template Services
    • Charles G.G. Schmidt Co.
