Subject: Re: Looking for CNC tech support - HOLZHER with OSAI Series 10 controller
12/8/21
Greg Phillips Member
I am hoping to get some tech support for a used CNC router we purchased. I am happy to pay for support (phone, email or on-site), just need someone who knows how to get it working. It’s an older machine but in excellent condition. It is a 1998 HOLZHER COSMEC SA-25 with an OSAI series 10 controller. I have previously owned many CNC's including a COSMEC Conquest 250 (also a 1998) with the same controller so I am familiar with the machine and how it operates. I currently have it setup and running and can run programs with the router, however, I am getting an error message “144 ATC Z axis not in higher position” (see attached photo) any time it calls out a tool change (M6 function) and it stops the program. I can manually load a tool and skip the tool change command, the router works but doesn’t use the tool offset table, so no tool compensation (G41, G42, etc.). This also prevents me from using the drill head, saw, etc. We thought it may be the dust hood not in the upper position, however, the dust hood is up and the corresponding sensor light is activated in the control cabinet so I don't think that is it. The manual M code commands for the individual tool changer functions work fine.
The company I bought it from has been helpful but never had this problem. I am also getting a "CMOS battery low" error and if it sits for a while (which it did before we bought it) it "forgets" everything...I have to enter offset and tool data each time. All the variables are blank also. I think there is a variable that it "forgot" which is causing the tool change error, but I don't know what it is. I do have a lot of backup files, but don't know how to install them or where they would go. Side question.... anyone know how to replace the CMOS battery?
I have called and emailed HOLZHER multiple times but they refuse to help, stating they no longer support that machine...it's too old. So anyone considering buying aa used (or new) HOLZHER machine, please be aware that they won't support older machines so in the future you may have low resale value or a boat anchor. Anyone out there who knows this controller or knows someone who can help?
12/9/21       #2: Looking for CNC tech support - HOLZ ...
Jared
I'm not familiar with that controller, but CMOS batteries are usually one of a few different types, depending on when the motherboard was manufactured. If you're lucky, it has a coin battery like a CR2032 that can just be swapped out. Given the time period, it might be a solder-on barrel battery, which are notorious for leaking and ruining nearby components. Dead ones need to be unsoldered or clipped off the board and a new 3v battery soldered in its place. Youtube has dozens of videos on the subject.
12/16/21       #3: Looking for CNC tech support - HOLZ ...
yaakov
is the mgazine have option go up/down by cylinder?
cheack if there sensor on z to confirm spindle on corect position
is someting happend until this error apear?
i mean is z move? y move?
in any case photo of yours magazine will help to understand
12/24/21       #4: Looking for CNC tech support - HOLZ ...
Acctek  Member
CNC machining center, mirror spark machine, slow-moving wire, drilling and tapping center, water mill, lathe and milling machine, precision grinder, turning and milling compound, gantry CNC enterprise
8/31/22       #5: Looking for CNC tech support - HOLZ ...
Devin LaLonde
Hello,
I also have a similar machine which uses the OSAI 10. Did you ever find the CMOS battery?
I found this file online of what seams to be the OSAI 10, but I don't see anything that looks like a battery.
Thanks!
Devin
View higher quality, full size image (1600 X 928)
View higher quality, full size image (1600 X 973)
9/23/23       #7: Looking for CNC tech support - HOLZ ...
Romeo
The battery is under the power converter module.
    • Country Saw and Knife
    • Better Vacuum Cups, Inc.
    • Template Services
