Subject: Re: Roller hold downs
Roller hold downs
12/17/21
Hi All.
I'm looking for feedback from anyone who has a roller hold down machine:
Do you like it?
What are the issues that you have with it?
What would you change?
2 rollers or 4?
And technically, roller diameter and cylinder diameter.
Thanks in advance to all.
12/30/21       #3: Roller hold downs ...
Thomas M Diel  Member
Website: http://thomasdiel.com
I procured for the company I worked at the time their first CNC, which was a Komo Mach II w/ 4qty approximately 3 1/2"dia roller hold-downs in 2006 and left that company in 2011. It had a 40hp vacuum pump and could hold a nest of 3/4"th import ply together with really small parts generally 100sqin but you would start to loose the smaller parts towards the end of the sheet, so cut the smallest stuff first. Tooling was 3E 3/8"dia rougher @ 900ipm for upholstered (hidden) ply parts or a compression bit 800ipm if making table parts. Since it was our first machine the primary requirement was the rollers had to be removable for hardwood / jig work. We took the rollers off constantly and made a jig that would push-off all for rollers onto total lock casters - rolling tables. The table was 5' across and the rollers weighed about 80lbs ea (heavy) and slammed down (loud). The air usage was considerably more because theirs was a air piston system and we installed a air tank reservoir close-by for line /pressure loss of the two screws downstream. At that time Komo was the only machine that had the removeable rollers as a standard. Accu-router is known for their roller hold down machines but didn't quote a removable set-up. Anderson also quoted a custom machine. SCM bowed out but said we did'nt need one. The second big program hurdle was Router-Cim was an Autocad add-on which I was familiar with and was cutting parts by the time install was set-up. Just after making the decision to purchase I had toured American Leather who was running two Komo's 2 shifts/day and I believe they have stayed that course. Good luck,
Tom
12/31/21       #4: Roller hold downs ...
Thanks Tom.
Very helpful.
    • Biesse America
    • SainSmart
      CNC and Engraving machines for Makers
    • Limtech Industries, Inc.
