Subject: Re: ball screw repair
ball screw repair
1/21/22
Jonathan Mahnken
Does anyone know of a mobile cnc tech in southern california who can do ball screw repair
1/22/22       #2: ball screw repair ...
I have always heard that screws need to be removed and sent out for service. I hope for you that isn't true. Post back if that is an option.
1/25/22       #3: ball screw repair ...
Rob Young  Member
Unless you are working with a small machine that uses a simple lead screw and brass ball screw nut you will need to send your ball screw out to have it properly repaired.
Proper repair of the ball screw and nut should be accomplished in a clean room. There are preload and backlash settings the manufacturer lists for their ball screws and these will need to be checked. It is also likely that you would need new journals, possibly oversized balls to accommodate the very likely ball screw grinding and recoating yours will probably require.
You will also want to replace the end bearings (likely there are thrust bearings) and in some cases with longer screws there may be a pretension when putting the screw back in.
I have used PSI in Livonia, MI in the past and been very satisfied with their work. I have linked them for you.
https://www.psi-repair.com
1/25/22       #4: ball screw repair ...
Jonathan Mahnken
Thanks. I have tracked down a mobile ball screw service. its pricey, but I dont have to figure out how to ship an 11' screw. I'll let you all know how it goes
    • Limtech Industries, Inc.
    • Template Services
    • Biesse America
