Subject: Re: rover b7 no band sensor down error
1/27/22
max shaw Member
hello i have the above error coming up when i go to machine something which i understand is either the air ram sensor on the side curtains or the slide sensor on the main hood. there is no lights showing on either barrel sensor, i have tried putting a ferrous bolt behind both reed sensors with no luck and also tried tapping metal on the slide sensor... the sensor on the left lights up but the sensor on the right doesnt light up at all. can anyone shed any light?
1/27/22       #3: rover b7 no band sensor down error ...
One of 3 things assuming the cylinder is in the right position:
The sensor has moved and is not reading the cylinder piston. Likely not the case if you've check with a magnet.
The sensor is bad - most likely
Broken wire - unplug the sensor and check for power - likely 24 VDC.
