Subject: Re: Panel saw variation
Panel saw variation
3/6/22
Good morning All.
We're just getting used to a new (to us) Giben Smart 65 panel saw.
I did a test cut of 10 100mm 1/2 melamine parts and got variations of 99.2mm to 99.8mm with most of the parts in the 99.5mm 99.6mm range.
Is this within the range of normal?
I'm also having some issues with the scoring blade. Sometimes the bottom is perfect, sometimes chipping on the front of the part and sometimes on the back. That makes no sense to me. Any ideas?
Thanks in advance.
3/6/22       #2: Panel saw variation ...
Rob Young  Member
Who installed your saw? All of these could be the result of an improper installation. Leveling, squaring, pull back test, setting the absolute position, all of these things must be properly done if you want a reliable and accurate saw.
3/6/22       #3: Panel saw variation ...
We installed it. We install all our own CNCs so took a shot at this.
It's square and level.
What's a pull back test?
3/7/22       #4: Panel saw variation ...
Rob Young  Member
The pull back test is used to ensure the pusher pulls back exactly parallel to the fences. Measuring an X pattern on the beams isn't accurate enough.
Regarding the sizes of your parts... The first thing you need to check is the absolute positioning. This will set the first piece accurate. If the incremental cuts are consistent but off in size than you will want to change your saw kerf. Afterwards recheck the absolute measurement and reset it if necessary.
Beam saws are one of those pieces of machinery that everyone thinks they have properly set up but there are fine details that make the difference between 100 percent accurate size, squareness of parts, a saw that doesn't wear prematurely and a saw that is close and likely to wear prematurely.
3/7/22       #5: Panel saw variation ...
Thanks.
3/7/22       #6: Panel saw variation ...
Does it use a tapered scoring or stacked scoring blade? Most common complaint is tapered scoring blade and bowing stock.
3/9/22       #7: Panel saw variation ...
yaakov
0.2+- mm(not inches) can be normal ,not because machine ,only because material cutting behavior
about scoring , first check if beam press enough on yours part
when you cut one so small piece and beam is so long ,and othere side also there pneumatic cylinder( even there bar inside to balance 2 side) there can be alway some 0.0 that one side press more ,then can get this scoring problem
firs solution is go up little with scoring
there some beam saw know to control pressure according part size
try pu small part on other side to be sure its not because that
beam saw its not cnc you can never get perfect diagonal ,or perfect size
(this according many years experience with selco)
3/14/22       #8: Panel saw variation ...
Acctek  Member
It should be debugged and tested many times before use
    • Biesse America
    • SainSmart
      CNC and Engraving machines for Makers
    • Limtech Industries, Inc.
