Subject: Re: Solid wood nesting tooling
5/4/22
Christoffer Söderqvist  Member
Website: http://www.exaktsnickeri.se
Hello, all!
We have recently acquired a Homag N-500 nesting cell. We plan to machine kitchen cabinet parts from 8' x 4' x 3/4" or 20 mm sheets of solid yellow pine. I've talked to the sales reps of Leuco, AKE & Leitz but they really don't know what tool to use for this.
I'm thinking 1/2" solid coated tungsten with an upspiral.
Anyone with experience from this?
Best regards,
Exakt Snickeri
Sweden
5/5/22       #2: Solid wood nesting tooling ...
FS Tools has an chipbreaker spiral solid carbide cutter recommended for softwoods and fast feedrate. Don't underestimate the ability of brazed straight flute carbide bits. This is what I use to cut out 1 1/2" thick pine parts on a vacuum fixture. I do a final full depth pass at .015" to finish the cut and get reasonable surface finish with only occasional break out at short grain corners.
5/5/22       #3: Solid wood nesting tooling ...
BH Davis  Member
I think a 3/8" bit would probably do the job for you. Less stress on the machine, lower amount of chips and faster feed rates. At least give it a try.
5/6/22       #4: Solid wood nesting tooling ...
Using an up spiral bit will depend on the ability of the vacuum to hold your work. If your pieces are small, the lifting action of the spiral will pull them off the table. You can use some toolpath strategies to help like a last pass at 1mm depth of cut and step over of .5mm. But you sacrifice speed.
5/6/22       #5: Solid wood nesting tooling ...
I can't imagine a 4X8 solid wood panel being consistently flat enough for nested CNC's.
Also, what about blow out in the corners?
Solid wood is a completely different animal than any kind of sheet goods or even plywood.
Up spiral bits can tear it pretty badly even with the grain, especially soft wood like pine. I'd look at chipbreaker compression spirals. You may need both left and right spirals to deal with the aforementioned corners.
5/9/22       #6: Solid wood nesting tooling ...
Acctek  Member
When cutting wood or composite wood materials, the damage of welded carbide milling cutters is often not due to tooth wear, but due to the disadvantages of high temperature welding or grinding heat during sharpening
5/10/22       #7: Solid wood nesting tooling ...
Quicktrim
Use a roughing bit hole cutting the parts slightly oversized. Vortex makes a nice 1/2 " roughing bit .
Then do a final pass with a sharp down spiral or straight flute taking off the final 0.01 or so .
Climb cut , and the corners on the right top and esp bottom of the parts may still chop out a bit .
Solid wood is not the easiest to machine on a router
5/13/22       #8: Solid wood nesting tooling ...
Skylaryer Member
Website: https://woodymanreviews.com
HOLZ-HER's nesting technology ensures efficient formatting and drilling on one machine. Here the panel is held by large-surface vacuum on a wear plate. The great advantage of this production method is production of exactly formatted workpieces, already provided with groove or rebate in the rear wall and all required vertical holes for shelves, connectors, etc.for the wood guide info woodyman https://woodymanreviews.com is the best i do use for wood guide and Above all the entire process is accomplished without additional handling work and is therefore extremely efficient in terms of time and resources.
5/13/22       #9: Solid wood nesting tooling ...
Skylarker and Acctek...
What does anything you wrote have to do with the original question?
5/17/22       #10: Solid wood nesting tooling ...
Dropout
I think Acctek is responding to my suggestion of using brazed carbide straight flutes as opposed to solid carbide or insert. It is true that the carbide used for brazed bits cannot take as sharp an edge nor are they as durable as solid carbide tooling. But in my experience with a light weight cnc the bits perform very well. Wear is less of an issue with cutting solid pine as long as you keep a large chip load. I had more corner breaks with spirals than with straight flutes except for a very low angle down shear bit.
5/17/22       #11: Solid wood nesting tooling ...
If so, my apologies to Acctek.
5/18/22       #12: Solid wood nesting tooling ...
You need a special brazed 2 flute as the standard flutes don't meet and will not plunge cut. You need ones that have a third piece of carbide added on the end.
