Subject: Re: It is necessary to cut plywood
6/20/22
Rudolf Member
I gonna cut plywood in different thickness and sizes. What about choosing a laser tube? What is the right way?
6/21/22       #2: It is necessary to cut plywood ...
MrKyle Member
1 mm plywood you will need 10 watts of laser tube power
7/12/22       #3: It is necessary to cut plywood ...
Adea00Leka Member
How fast do you have to cut? It depends on the power CNC wood router.
https://wattsan.com/cnc-wood-routers/
8/2/22       #4: It is necessary to cut plywood ...
Acctek  Member
It is mainly considered from the aspects of laser output power, auxiliary gas type and cutting material type. For example, the laser power, when the auxiliary gas is air, also cuts carbon steel plate, 3000W can cut 3mm carbon steel plate, and 6000W can cut 6mm carbon steel plate. The higher the power, the thicker the thickness that can be cut. Similarly, different auxiliary gases and cutting materials have different thicknesses that can be cut.
    • Machinery Associates
