Subject: Re: Biesse CIX code
Biesse CIX code
10/21/19
Bob Member
Anyone have a good grasp of generating CIX code?
I am trying to write a post for my app and the documentation provided is pretty poor.
Looks like I only got about 25% of whatever manual they have because it constantly refers to pages that are not included. They say thats all they have.
Opening a ticket is slow going just to get a basic answer.
I am looking for someone that I can email once in a while about basic stuff.
Right now I am stuck on cutting an arc with start and finish point with a radius.
I drew a part in BSolid using this method but when I look at the CIX the macro that is generated is an arc with 3 points.
I am just doing basic 2D parts cutouts.
I think I have the boring going.
Thanks for any help
Bob
10/25/19       #2: Biesse CIX code ...
Marek  Member
Website: http://www.cadcam-softcz.cz
Let me know if you will need something, i have many experience with CIX files. I wrote many postprocessors for Biesse machines.
10/25/19       #3: Biesse CIX code ...
Bob Member
Thanks Marek
It has been a pretty rough week but I am finally making progress.
Once finding out few things that really helped.
That on the line macro that the x and y are absolute and Z is always relative.There is not any absolute Z. Kind of crazy but, now that I know, I can work with it.
I also found you had to just draw a single arc with a radius to get Bsolid to generate the CIX that way. If you draw it in a connected polyline it generates it as a arc with 3 points.
All I got sent was a CIX command sheet.
It referenced pages that was not included.
I found it was referencing a Biesseworks manual. So I asked for one. The one I got the pages did not match the CIX command list pdf. I finally threw out the CIX command pdf and worked from the full manual.
Once I got a ticket going, Giacomo from Biesse Canada has been really helpful.
I had a much easier time learning writing Gcode from the old XNC manual. I don't remember ever having to ask for help.
I found that most of the lines in CIX generated by Bsolid are not needed, so the code is not nearly as verbose as it looked.
It's been a tough start, but I think I am ready to start changing my post from iso to CIX and take advantage of the optimized boring.
That will teach me not to skip a generation of Biesse software. I think they are under the impression that everyone has moved right along with them. :-)
8/12/21       #4: Biesse CIX code ...
Bobkalil Member
Hi, please help! I have a Biesse skill 300 accept cix format file for biessework anyone know which cad/cam software I can use for nesting and engraving?
6/22/22       #7: Biesse CIX code ...
Max
Hello, Bob!
Can you post full manual for CIX format, plase?
I can't found any documentations for programming on CIX format..
    • Limtech Industries, Inc.
