Subject: Re: BIESSE ROVER K 1532 G _ ERROR
4/30/17
ANTONY Member
DEAR ALL,
MACHINE STOPS WITH THE FOLLOWING ERROR
PLEASE REFER THE PICTURE FOR ERROR MESSAGE
E CAT 1363
ETHERNET CAT CABLE DISCONNECTED
MACHINE POWER OFF
AGAIN I HAVE TO RESTART TO RUN MACHINE
View higher quality, full size image (431 X 448)
5/4/17       #4: BIESSE ROVER K 1532 G _ ERROR ...
ANTONY Member
DISABLING ANTIVIRUS, WILL SOLVE THIS ISSUE... THANK YOU
5/28/17       #5: BIESSE ROVER K 1532 G _ ERROR ...
ANTONY JOHN Member
PLEASE LET ME KNOW THE OPTIMUM FEED AND RPM FOR BIESSE ROVER LAMA 120 SAW CUTTER. FOR CHIP BOARD AND MDF. IF I ENABLE TOOL CLASS MANAGEMENT THE FEES VERY LOW. PLEASE HELP. THANK YOU
4/5/22       #8: BIESSE ROVER K 1532 G _ ERROR ...
justin
I currently have the same problem as you on my biesse, but I don't understand why disabling the antivirus can solve the problem? We have been looking for the problem for some time and I just came across your subject... thank you
7/7/22       #9: BIESSE ROVER K 1532 G _ ERROR ...
Michael L
I believe this is a bad connection from PC to PLC card. It could be a PLC card over heating but more likely a bad cable. Try replacing Ethernet cable from PC to the card that is going to servos.
    • Machinery Associates
    • Country Saw and Knife
