Subject: Re: "waves" on the product
8/5/22
Rudolf  Member
Website: wattsan.com/
Hi all. Can you please tell me where these "waves" on the product come from and how to get rid of them?
View higher quality, full size image (3000 X 4000)
https://wattsan.com/cnc-wood-routers/
8/5/22       #2: "waves" on the product ...
cris
That's a toolpathing issue. try a remachine toolpath in the area you need corrected.
8/5/22       #3: "waves" on the product ...
Looks to me like something in your CAD file. Assuming this is machined from and STL?
8/5/22       #4: "waves" on the product ...
Machine rigidity issue. The valleys are where the bit is more fully engaged leading to machine deflecting. Recut with a shallow depth of cut and you will probably get better results
8/5/22       #5: "waves" on the product ...
Is that a 5 axis machine or 3? Conrol?
8/5/22       #6: "waves" on the product ...
Whatever machine is it whether 3 or 5 Axis I would say RichC is correct and DO NOT BUY a wattsan machine... they look like junk.
8/5/22       #7: "waves" on the product ...
8/6/22       #8: "waves" on the product ...
james e mcgrew  Member
A ballnose bit will leave these marks due to stepover on rise and falls, try changing the angle of direction and just re-machine the specific area.
Which software are You using. if it is Aspire or Vectric give me a call and i can show you this online
View higher quality, full size image (1023 X 682)
View higher quality, full size image (800 X 451)
8/8/22       #9: "waves" on the product ...
Acctek  Member
The parameters set by the motor are unreasonable, too high or too low will cause high-frequency or low-frequency vibration to cause ripples.
8/16/22       #10: "waves" on the product ...
Rudolf  Member
thanks for the feedback)) I will check CAD files!
8/16/22       #11: "waves" on the product ...
Rudolf  Member
james e mcgrew
Thanks for advice.
I use Vectric.
8/16/22       #12: "waves" on the product ...
Rudolf  Member
Thank you guys very much, you've helped me a lot.
    • Template Services
    • Charles G.G. Schmidt Co.
