Subject: Re: How to zero machine coordinates on the Richauto A18
9/7/22
Michael Member
Website: https://wattsan.com
I have CNC Wattsan M1 6090. The control system is a DSP Richauto A18.
The problem is that in the HOME point where the encoders are located, the machine coordinate system does not contain zeros, but rather some values. As a result, the working field is limited on one side and goes beyond the physical stops on the other. If you move the machine manually, you can move in.
How do I reset the machine coordinates to zero at the HOME point?
https://wattsan.com/product/wattsan-6090/
9/8/22       #2: How to zero machine coordinates on ...
I have given the advice before that this forum has had extremely few discussions about laser cutters/engravers. How a machine can go beyond it's physical stops would seem like an impossibility. What has Watson suggested?
    • Template Services
