Subject: Re: CNC file for work van
10/12/22
Nick Cook Member
Website: http://kootenaicabinets.com
We have a newly acquired Ford TransitXL. Any information about where to get a CNC file for cutting a floor for it? We'd like to deliver small cabinet jobs in it. It would be nice to cut it out on the CNC.
10/13/22       #2: CNC file for work van ...
BH Davis  Member
Here are two things you can do.
1) Go to the Ford Transit forum and ask your question there.
https://www.fordtransitusaforum.com/
2) Remove the existing floor covering from the van and lay it out on the CNC. Then put a laser pointer (like those used in presentations) on the Z axis and move it along the edge of the floor. Move it a few inches at a time and record the x,y positions. Then enter those into AutoCAD or similar as a spline. Of course if your CNC has a digitizing feature you can use that to create the file.
10/13/22       #3: CNC file for work van ...
Nick Cook Member
That's great thanks. Unfortunately, it came to us with just a meatal floor, nothing to remove. But I'll try the forum. Thanks.
10/13/22       #4: CNC file for work van ...
BH Davis  Member
I've occasionally laid vinyl floors in tight spaces. I'm not all that experienced in that area so find I get a better fit if I make a template to lay on the actual vinyl material to make the cut.
I'd make a kraft or rosin paper template that came within a couple inches of the walls and then use a 3" or so offset block to trace the walls onto the paper.
Then I'd put the template on the vinyl and use the block again to make a parallel line on the vinyl that is the block distance out from the template line. Works like a charm.
In your case instead of cutting vinyl to lay it down you can take the template to the CNC to digitize the line. Or go old school and draw the shape on your floor material just like I did with the vinyl.
10/13/22       #5: CNC file for work van ...
Nick Cook Member
If I can't get a file I'll go that route. I'll trace it on to plywood and jig saw it.
10/13/22       #6: CNC file for work van ...
BH Davis  Member
There's something to be said for the laser point digitizing method. Once done the first time it's a process you will most likely find useful in the future.
10/13/22       #7: CNC file for work van ...
How a buddy who has a laser counter top measuring system?
10/13/22       #8: CNC file for work van ...
Nick Cook Member
We work with a granite company alot, maybe they could do the laser template.
10/13/22       #9: CNC file for work van ...
Foam is not a good choice for sliding items into the van. I have a Transit Connect and the floor has a grippy rubber mat in it. If I want to slide, I lay down strips of plywood. You might look at van life websites too. Lots of DIY for making them into living quarters.
10/13/22       #10: CNC file for work van ...
BH Davis  Member
I think the laser counter top measuring system may not be good for such short distance changes in shape. I could be wrong on this though so probably better to ask your customer with the system. That would definitely be a good way to do it if it will work.
10/15/22       #11: CNC file for work van ...
If I couldnt find a file for the van (likely tough to do even possibly with floor mat companies that likely wont share their files) I would just get in there with a tape/rule/laser measure, and template it on paper then draw it in CAD, cut it on the CNC in a large sheet of cardboard or mark it on the carboard on the CNC with a sharpie in the collet and cut it out, drop the carboard in and make whatever minor adjustments to your CAD file then cut it in ply. Likely just as fast to just template the floor with carboard old school then go the conventional route (jig saw/etc) but it would be a lot nicer with a routed floor for sure.
I have never had any luck getting drawings from any commercial source as they wont turn loose of them. One place you may try is to reach out to some of the vanbuild forums on Reddit. There are numerous people building out vans for a living for traveling/camping. Someone there may have a full accurate interior CAD file. Whether they will turn it loose or not who knows.
10/15/22       #12: CNC file for work van ...
P.S. Link attached for google, ford transit floor plan CAD drawing -->images. How accurate they are who knows but looks like several are pretty well dimensioned.
https://duckduckgo.com/?q=ford+transi+floor+cad+drawing&atb=v314-1&iax=images&iai=https%3A%2F%2Fi.pinimg.com%2F736x%2Fa7%2F7a%2F24%2Fa77a241d25349e932a40c396398266cb.jpg&ia=images
10/15/22       #13: CNC file for work van ...
BH Davis  Member
It finally occurred to me that I should mention what I did on my Transit van. I simply laid a 1/4" sheet of plywood down on the floor. The van came with a rubber floor I wanted to protect from sliding other stuff in and out.
I cut a 1" long scarf joint on one end of the 4x8 sheet and then did the same on a 24" x 48" piece. Glued them together to get a 10' long panel and they just sit on the floor. They move around a bit but not much.
Does the job nicely.
11/30/22       #14: CNC file for work van ...
Adea00Leka Member
Website: https://virmer.com/
Something I did not understand the complexity of simply laying the floor of the car with a regular chipboard or you have some universal curves. give me the measurements.
https://virmer.com/catalog/cnc-milling-machines/
11/30/22       #15: CNC file for work van ...
Nicholas Cook III
We ended up doing it by hand and it came out really nice, probably ended up being a little faster overall. I like the ideas and appreciate everyone that made suggestions. Hope you all have a great Christmas season.
11/30/22       #16: CNC file for work van ...
Mark B
A lot of things are just not faster on the CNC unless your running multiples. If you were producing van floors, generating, tweaking, and refining, the file would be a win.. but a one off... not so much.
    • Biesse America
    • SainSmart
      CNC and Engraving machines for Makers
    • Limtech Industries, Inc.
