Subject: Re: Scm Error Message
Scm Error Message
12/19/22
Bylla Member
Hej guys! We work on a scm record 25 and had in the last weeks some sudden machinestops with message "PLC 112: mats overtravel microswitch fault". This happens at any place on x/y/z-position, it just stopps movement and shuts down power (just on the panel, not the whole machine) . Machine can simply be started again. This seems to happen especially when we cut much ABS-plastics. Its not a big problem, but when it happens 5 times on one piece, its annoying. Found nothing about this code in the manual. 1. Does anyone know what this message means? Scm-service here in sweden is not really available for so small problems.. 2. Could it be some kind of electrostatic charge, which causes this problem? Thanks for any idea!
12/20/22       #2: Scm errormessage ...
My guess is static considering the time of year and the material being cut. Adding a copper ground wire in the dust collection flex hose might help.
12/20/22       #3: Scm Error Message ...
Bylla Member
Hej, yeah, great! I also suspected that. We have a exhausting plant on wheels, which is not really grounded. Will try to fix that at the nect step.
Thank you!
12/21/22       #4: Scm Error Message ...
You may also want to tie the 2 grounds together.
    • Template Services
