Subject: Re: Cam software with spindle rotation control and drill bank control wante
Cam software with spindle rotation control and drill bank control wanted.
4/8/23
Quicktrim
Website: http://jonathankorban.com
I am needing things machined in two directions to control tear out on solid wood parts as well as pockets and patterns that enter and exit edge banded parts.
Much like the puzzle lock miter that Karl posted recently.
So does anyone know of a software that offers this functionality that is not crazy expensive ? I wouldn't mind paying a few thousand or up to five thousand for such software but I don't want to pay a 300.00 to 500.00 fee every month for a software that I will only use a couple times a year.
I run an Anderson CNC so I don't have native control or software such as woodwop or biesseworks.
Thanks !
4/9/23       #2: Cam software with spindle rotation ...
jerry Member
Do you mean movement. If that is what you mean then check out Vectric products. You can cut in conventional or climb that makes the spindle travel agaisnt the grain.
4/9/23       #3: Cam software with spindle rotation ...
Quicktrim
I have vectric v carve pro. It does let you clb cut but I can't see anywhere to control the spindle rotation ( CCW needed )
Does anyone with vectric Aspire know if it includes this functionally ?
Or does anyone know if Enroute would do this ?
I assume mastercam does but is quite expensive .
4/9/23       #4: Cam software with spindle rotation ...
jerry Member
Why not send Vectric a request to have custom post p written or ask on their forum
4/9/23       #5: Cam software with spindle rotation ...
Richard
I'm not sure if Enroute can do this directly, I can have a look tomorrow. But it might be possible to do it with a customised post processor.
However you could easily edit the G-code. It's just a matter of switching from M03 to M04. As you would have to use a tool that is designed for CCW rotation it would be fairly easy to find the tool change in the code and switch from the standard M03 to M04. If you are only doing this a couple of times a year I think that would be easy enough.
4/9/23       #6: Cam software with spindle rotation ...
BH Davis  Member
I'm not sure if this is what you mean but I always ran multiple passes with Enroute. The first would be climb cut and the 2nd and 3rd would be conventional cuts.
4/10/23       #7: Cam software with spindle rotation ...
CalCurated Member
Enroute can modify a driver for your machine that would change the rotation if a negative RPM is used.
You can view, purchase or download a trial of enroute here.
https://saisubscriptions.com/products/enroute/er-all-sai-global?reseller_id=CALCUR
001
Let me know if I can be of more assistance.
4/10/23       #8: Cam software with spindle rotation ...
Sheetcam will do it.
https://www.sheetcam.com/
4/10/23       #9: Cam software with spindle rotation ...
Vectric will not support drill banks nor spindle rotation reversal. It would be possible to edit a file to reverse the rotation but it would have to be done manually.
Someone smarter than me could write a subroutine to reverse the spindle when specific tools are called I suspect.
4/10/23       #10: Cam software with spindle rotation ...
Quicktrim
Thank you for the responses.
I like the idea that Enroute can use a negative spindle speed number to run CCW.
It has also made me think about G Code and Modifying code with the spindle rotation value. I think I could make this work at least as a trial run to see if it would work easily. I just don't want to forget and run a program. I suppose if I run it with no part first and watch the rotation I should be ok.
4/12/23       #11: Cam software with spindle rotation ...
Erick Member
Website: https://virmer.com/
I can offer Vectric only.
https://virmer.com/catalog/cnc-milling-machines/
4/12/23       #12: Cam software with spindle rotation ...
Gary B. Member
Maybe I'm missing something, but why on earth would you want to reverse the spindle? I can see climb cutting through changing the tool path direction, but reversing the spindle requires a different bit. This should be setup through your machine's parameters, at your machine, for that specific tool.
FWIW, we run "Left hand" bits regularly, but like I said, this is controlled at the machine controller for that specific tool.
4/12/23       #13: Cam software with spindle rotation ...
You reverse the spindle rotation to use left and right tooling. It opens up options.
Quicktrim - I did that in woodWOP, but that's a Weeke/Homag thing only.
    • Machinery Associates
    • Country Saw and Knife
