Subject: Re: Biesse CNC
Biesse CNC
8/1/23
Roger Forst  Member
I am running a Biesse Rover A and I'd like to find a way to label parts so that I can identify and keep them straight after nesting. When running a sheet that has 8 parts that are slightly different it becomes a real nightmare.
I've tried adding text in Autocad and also adding test in Biesseworks but these both disappear during nesting different parts on a full sheet.
We do not have the label printer attachment for our machine,
Does anyone have any suggestions.
Please let me know.
Thank you
8/13/23       #2: Biesse CNC ...
Justin Morris  Member
Website: https://www.centexautomation.net/
Most times you will need your nesting software to output a print job along with the sheet file. If the machine does not have a built-in printer like what you described, most customers will have a separate PC where they offload the parts from the machine and have the labels print at that location then apply the labels manually.
    • Better Vacuum Cups, Inc.
    • Limtech Industries, Inc.
