Subject: Re: Life expectancy of flexible dust hose from your CNC to the header?
8/14/23
Matt
The past 6 or 7 years, I seem to have to replace the main flexible dust hose going from our dust collector header down to the gantry way more than we used to. Seems like I get barely 1-2 years out of it.
This has been on two different CNC routers (4x8 and 5x10), and we've rearranged the positioning of the overhead connection in a number of ways to help relieve the stress on it.
We're cutting a lot of melamine, which is quite abrasive, so it's understandable that it takes a lot of abuse. But this seems excessive to me.
The failure point is always at a stress spot-- either where it clamps to the gantry, or it clamps to the overhead connection. It seems like I can minimize one, but it puts all the pressure back on the other.
Given that we need the anti-static hose, this starts getting quite expensive quickly.
Any suggestions on what lasts?
8/14/23       #2: Life expectancy of flexible dust ho ...
Justin Morris  Member
Website: https://www.centexautomation.net/
Do you have any pictures of the router head at its furthest position from where the drop point is located?
Another picture with the spindle head at the center of the machine in both X and Y directions?
Both pictures need to be taken with the dust collector on so the slack from the hose is taken up.
8/14/23       #3: Life expectancy of flexible dust ho ...
Our lasts years, I can tell you how many because we have not replaced one.
Do you use one of these?
Ball Joint
8/14/23       #4: Life expectancy of flexible dust ho ...
Is replacing every 2 years a major expense for your company?
