Subject: Re: Beamsaw light beam
Beamsaw light beam
8/29/23
David wilson Member
Beamsaw is not picking up dark colours of mfc/mdf , if i put a off cut of white infront of my cut it will then recorgnize and cut. Any advice would be great. David wilson.
8/29/23       #2: Beamsaw light beam ...
Make sure everything is clean.
We had problems when cutting some plastics that the static would cause plastic dust to cover the light.
8/31/23       #3: Beamsaw light beam ...
Erick Member
Website: https://wattsan.com/
If your beamsaw is having trouble picking up dark colors of MFC/MDF materials, there are a few things you can try to improve the recognition and cutting accuracy:
1. Ensure that the work area is well-lit, especially around the cutting area.
2. Increase the contrast between the dark material and the background. You mentioned that placing a white off-cut in front of the cut helps with recognition. You can try using contrasting materials or backgrounds to enhance the visibility of the dark-colored material for the beamsaw.
3. Check the calibration of the beamsaw's sensors. Over time, calibration may become slightly off, affecting the accuracy of material detection.
https://wattsan.com/laser-cutting-machines
