Subject: Re: Vacuum pump turning off
12/27/23
Tim Moiseyeno Member
Hello everybody, so we have a situation here, our brand new vacuum pump (becker-international VTLF) keeps turning off after about 10 minutes of running.
We are pretty sure that it is overheating because it is backed into a corner so we ataxhed atube to the exhast and directed it far enough away that it wouldnt bother the pump, and it still turns off after 10 minutes.
we are thinking about putting an enclosure around it with a powerfull exhaust fan. Do you guys rhink this would work, what else could be causing the issue??!
12/27/23       #2: Vacuum pump turning off ...
Andrew
Website: http://frontrangecnc.com
Sounds like most likely your breaker or starter is undersized or undertuned. If you are not above 3k in altitude the pump should pull just under 30 amps at 208-230 roughly. Check that first :)
12/28/23       #3: Vacuum pump turning off ...
Rob Pierce
Check that the relief valve that is attached to the filter box is clean. It may have debris buildup in it causing the pump to over heat. Also check that when pulling a full vacuum with the table all closed off you have between-.780 to -.790 bar. Any more and it will over heat. You adjust the relief valve for that.
12/29/23       #4: Vacuum pump turning off ...
I agree with Andrew, how long have you had it? We got a new one and the switch which has the overload protection was set too low. Easy fix.
Good luck
1/29/24       #5: Vacuum pump turning off ...
Michael Member
Website: https://wattsan.com
Overheating and vacuum pump shutdown can be caused by several reasons. Here are some possible causes and remedies:
1. Poor Ventilation: As you mentioned, the pump may not be getting enough airflow, causing it to overheat.
2. Inadequate cooling: The pump may have a problem with the internal cooling system. Check to see if the pump's cooling mechanisms, such as fans or radiators, are working properly.
3. Electrical problems: Faulty motor or wiring.
    • Limtech Industries, Inc.
