Subject: Re: Aspire post for Fanuc
12/29/23
Hi all,
I started playing with Aspire for a particular project coming up. Can anyone recommend a post from the list or a generic Fanuc post that would be best suited for my Northwood? I was hoping to keep edits to a minimum since there will be a lot of different programs. Thanks. Also, it seems that from what I have played with, I just see G1 linear moves. Is there a post for arc output? Sorry I am an Aspire novice. Thanks.
1/2/24       #2: Aspire post for Fanuc ...
Maybe try an Vectric forum? Specify the control model, i.e. 210i, as well as Northwood.
I think Vectric has the ability to write/edit posts. Just play with/edit one until you find an output that is the same as whatever you currently use for the Northwood.
Pretty simple once you get into it.
