Subject: Re: Software question
Software question
1/16/24
Edvin
Our company is receiving our brand new HolzHer Epicon 7135 5-axis CNC in a few weeks, to replace our ageing UniMaster 7217.
At the same time, we are looking to change from AutoCad to a 3D CAD solution.
I realize everyone has their own opinion on what is the best software, so instead, I would like recommendations to which software works best with the HolzHer cnc / Campus 7 package.
I am already looking at new software and have found quite a few options.
-Fusion 360
-Onshape
-SolidEdge
-Solidworks
-Inventor
-Sketchup
-Freecad
What we are looking for is a program that:
-Works well with Campus/HolzHer software and hardware
-Makes it possible to machine files directly without exporting via STEP etc. or 3rd party software
-Meets our needs with >80% wooden cabinets and 3-axis parts in wood production, <20% 5-axis machining, also wood
-User-friendly, and easy to learn
-Cost-friendly
-Reliable
All and any input is appreciated.
1/18/24       #2: Software question ...
Rodney Member
If i had it to do over I would prob go mozaik investment is lot less, whith that being said i have used cabinet vision for 20 plus years, learing curv is steep, we recently just add a router to our production we have about 80 percent of the module's we just upgrade to screen to machine that was almost 7k alone including machine intergration,witch dosent include labeling for now we just do it with a sharpe or pencil witch works we are probably going to add soon to more streamline the process another 2,400 bucks, just have to many years invested to start over.
1/21/24       #3: Software question ...
Edvin
Thanks Rodney. I have not looked at Mozaik before. It seems like impressive software, I'll certainly keep it mind. However it's not quite what I'm looking for. What we need is software capable of 3d design and 5-axis cam with the HolzHer machine.
1/21/24       #4: Software question ...
Derrek
Mosaic and Cabinet Vision will do what you are looking for it will generate code and output directly to the machine. You don’t need it go into the machine software. I tried to be cheap early on and not get the full Cv package. When I went to full CV screen to machine it saved me thousands of dollars a year when I went away from the factory software. Don’t hinder yourself
1/26/24       #5: Software question ...
Ian
Doesn't campus 7 have a module for cabinet design? We use Alphacam for our Holzher promaster, but we are mostly manufacturing stair parts from .stp files, imported. Alphacam does have very good parametric functions from a template.
1/26/24       #6: Software question ...
Edvin
Hi Ian,
yes, I believe it does. I have also looked at Alphacam previously.
What software do you use to make your .stp files?
What I really am looking for, is software that lets me do every operation in one program. I see Fusion 360 has a CAM function, and Onshape has a CAM module in the works. For Solidworks, there is a Swood plugin, for cabinet making and CAM in Solidworks. But that solution is expensive! And to be honest, I'm not that big of fan of SW. It is slow and bugridden.
1/26/24       #7: Software question ...
Ian
For our extremely complicated parts, we farm out STEP files, but I use Megacad for all of my 2D and 3D in house work. What type of work that you're doing requires a solid model?
1/28/24       #8: Software question ...
Edvin
Well, that's the thing. Being a woodshop specializing in on off jobs, we never know what the next customer wants. One job that comes to mind is a spiral staircase with three radii and inset handrail in a curvy spliney shape. Would not have been possible using 2d cad.
Have not looked at MegaCad before, I'll add it to my list.
1/28/24       #9: Software question ...
Ian
The rail sweep features in fusion are pretty good, and you're familiar with Autocad methods already. Might want to check that out too. I prefer alphacam to import solid files, but as far as just creating a solid part, you wouldn't need the fusion CAM. I personally hate autodesk, especially its cloud based setup, but others love it.
2/19/24       #10: Software question ...
Arrow  Member
Website: Arrowdesigncustoms.com
Routercim by cimtech is crazy powerful. Been using it for the past 2 decades.
2/19/24       #11: Software question ...
I was speaking with Autodesk and their CAM team about Fusion 360 for 4 axis work. Specifically speaking about getting C axis turns and various routing operations on the side of panels or on planes that are not on G18 or G19 planes. I was told no, its not supported. Scratch them off your list.
