Subject: Re: importing PRV files into Schelling CNC Saw Software
2/19/24
Daniel Member
We have recently purchased a secondhand Schelling S45 beamsaw and have had issues with the HPO optimising software. IMA Schelling support have looked at the issue and come to the conclusion that the only fix is to re-license the software at around $17k.
Although this is ultimately one of our options, I know of much cheaper optimising software. The issue I'm having is loading the post processed files (in PRV format) into the saw.
Support for the software that I'm trialing suggests I need to open the PRV files in the HPO software to then import into the Saws Operating software.
I've tried opening these files but the file extensions are .001, .002, .003 and so on. Can anyone point me in the right direction?
2/19/24       #3: importing PRV files into Schelling ...
Justin Morris  Member
Website: https://www.centexautomation.net/
have you tried simply changing the extension of the file from .001 to .prv?
2/20/24       #4: importing PRV files into Schelling ...
Daniel Member
Yes Justin, I've tried changing the file extension. There must be a method of importation that I'm missing, as there are several PRV.001 files in different job files from the previous owner.
I've contacted the previous owner by email and submitted this question around the same time so I might have to give him a call.
