Subject: Re: Pod and rail aggregate saw
2/28/24
Dave Edgerton  Member
We just purchased a holher 7226 pod and rail. Has x-y and a caxis.
Onboard x-y saw.
Can we add an aggregate tool head with a saw that will cut in any angle other than 90 deg in x-y direction?
If we want to trim a long taper on a panel for example rather than routing it?
I should add we work primarily with solid wood for furniture Parts. Very little panel work
2/29/24       #2: Pod and rail aggregate saw ...
LIke this? Yes. Holtzer? Not sure.Probably. You will have to check with their support and how you are outputting code. This was done with Alphacam.
https://www.youtube.com/watch?v=6XQuWbY3SZw&t=1s
2/29/24       #3: Pod and rail aggregate saw ...
Here is another one. Very doable. You should be fine
https://www.youtube.com/watch?v=jqUce0u1VZM&t=36s
2/29/24       #4: Pod and rail aggregate saw ...
No, i mean the path of travel is not parallel to x or y axis but at say 30 degrees.
2/29/24       #5: Pod and rail aggregate saw ...
Path direction doesn't matter. X, Y, or X and Y.
You can even cut on X,Y, and Z.
2/29/24       #6: Pod and rail aggregate saw ...
Sorry. Your machine is probably capable, but your post processor needs to support it. I can manually program that stuff if necessary, but I rarely need to. My post processor is pretty good. It can all be figured out with aggregate data, saw diameter, and saw kerf. Good luck.
3/2/24       #7: Pod and rail aggregate saw ...
quick question. How are you posting your code? Alphacam, Mastercam, or something else?
3/15/24       #8: Pod and rail aggregate saw ...
Dave,
I made a panel today and then I thought that this is what you were interested in. First saw cut is in X,Y and at a 16.7° angle.
https://www.youtube.com/watch?v=TxIsIxP94cc
3/15/24       #9: Pod and rail aggregate saw ...
Mike that is exactly what i want to do. I think the onboard saw is onlyx-y so i would need an aggregate head like yours.
3/15/24       #10: Pod and rail aggregate saw ...
I have two Benz Oil bath and 4 Atemag(Techniks) heads. Been pleased with all of them, but lately I prefer Atemag. They seem to sound better. You can't really go wrong with either.
3/19/24       #11: Pod and rail aggregate saw ...
Erick Member
Website: https://wattsan.com/
Practically all the Atemag machines are suitable for an aggregate tool head, that`s why I love them
3/20/24       #12: Pod and rail aggregate saw ...
I think his Chinese to English translator is broken.
    • Limtech Industries, Inc.
