Subject: Re: SCM pratix s12 issue
5/22/24
Manieq Member
Hi all. I have a problem with sintesi handheld on pratix s12 (2013). I had to replace a computer. I have installed xilog plus and maestro and restored backup files but I can't import file to controller. On previous computer was folder where maestro saved post processed program and controller knew where from to import file. Does anyone know how to set up connection to make it work again
5/23/24       #3: SCM pratix s12 issue ...
Karl Member
Website: https://wattsan.com/
To resolve the issue, ensure that the folder path where Maestro saves post-processed programs matches the expected path on the controller. You may need to configure Maestro to save files to the correct directory. Check the settings in Maestro for the output path and verify that it corresponds with the import path used by the Sintesi handheld on your Pratix S12. If the settings are correct, you might need to re-establish network connections or sharing permissions between the new computer and the controller.
    • Limtech Industries, Inc.
