Subject: Re: Drill Bank Operation
5/29/24
AJ
Hello
I am in the process of learning to use the drill bank on my shops CNC machine. Unfortunately, no one else here has ever used it before so Im very much starting from scratch. Im looking for any information at all to get me going.
We have a Selexx 510 with 9 drill heads. We use EnRoute to write our files.
Ive looked on youtube and surprisingly havent gotten very far with figuring out how to set it up, what settings to use, etc. Please, any advice, any suggestions would be so much appreciated.
5/30/24       #2: Drill Bank Operation ...
Jim Anderson
Website: http://solidcam.com
In Enroute under machine set up select drill bank make sure it is checked, then click to edit, you will have to input your drills and their locations. On the machine, there is normally an offset from the spindle for the drill locations either in the parameters or work coordinates. The software will call the drills based on your setup. The machine will use that information to locate its position.
DrillBank.pdf
    • Limtech Industries, Inc.
