Subject: Re: Upgrading computer - SCM Pratix S15C
5/22/24
Evan
The shop I work at bought a SCM pratix S15C used in 2021. We have some larger files that we’d like to run but we encountered a error in panelmac “Exept[4,1] - Xil: Not enough memory.” We ordered and upgraded the RAM and figured out that we run Windows 7 32-bit so 4GB it had was the maximum usable.
We are looking into a used windows 7 64-bit computer to replace the existing computer. I’m hoping for some guidance. I’ve heard of people upgrading their CNC computers but I haven’t spoken to anyone personally. I have read that most 32-bit software will run on 64-bit systems but I’ve also read that Xialog and PanelMac might be exceptions to this. I also imagine that there are drivers that need to be installed.
Has anyone done this before who can lend some of their wisdom or point me in the right direction?
5/23/24       #2: Upgrading computer - SCM Pratix S15 ...
jerry Member
What model computer do you have. It may be able to run windows 32
5/23/24       #3: Upgrading computer - SCM Pratix S15 ...
jerry Member
What model computer do you have. It may be able to run windows 64
5/23/24       #4: Upgrading computer - SCM Pratix S15 ...
Charlie Member
Website: https://virmer.com/
but remember that you need at least 8GB RAM and always check the compatibility
5/23/24       #5: Upgrading computer - SCM Pratix S15 ...
Evan Member
Jerry - The computer is capable of upgrading to 64 bit, but we have to reformat the drive to do so, and we don't want to be stuck without a computer for the CNC. We'd prefer to buy a cheap comptuer that already has most of the spec's and load everything onto it so that we still have an operable CNC while we troubleshoot whatever issues arise getting the new computer to work.
Charlie - We bought 32GB of RAM that we sucuessfully installed before realizing that our system will only use 4GB. The computer I have my eye on is compatible with the RAM we already have bought.
5/31/24       #6: Upgrading computer - SCM Pratix S15 ...
jerry Member
I think I would clone the drive and install a 64 bit software on it then I would try to upgrade the original one with keep your files.
6/12/24       #7: Upgrading computer - SCM Pratix S15 ...
Brian
You said that you have some program files that are too large for the controller memory is that correct? There is surely a way to "drip feed" them into the controller. I don't remember the correct name but I've been drip feeding into Fanuc controllers since day one in fact it is the only way I feed a Fanuc as it is easier. Check and see if that is possible, if it is there will be no limit as to the file size.
7/11/24       #8: Upgrading computer - SCM Pratix S15 ...
Barney Member
It is surprising that a program could run the entire computer dry of memory, even one with 'only' 4GB of usable RAM. Much more common is that the amount of memory that Xilog reserves for programs is exceeded.
Apologies if you have already thought of this, or if my suggestion is coming too late, but have you tried setting the maximum memory in Xilog?
For that you need to go to Xilog's installation directory and look for `Xilog3.ini` in the `Bin` folder. Then change the [MEM] option to XILK=999, which I believe is the maximum.
Changing the computer is a major undertaking, but if you have successfully done it by now, do let me know - we could do with some pointers for changing the *truly* ancient WinXP computer on our SCM machine!
    • Limtech Industries, Inc.
