Subject: Re: OSAI conrol need help
6/2/24
Pavlo Member
Writing here due to find out that some questions about OSAI CNC have answered and that is great.
Appreceate any help/suggestion or advice as offical support of OSAI said that they limited and can't help.
So my case - I have Uniteam Wind 40 OSAI 10 controled CNC 2004.
Mostly everything is working good, I have tune postprocessor for Powermill(if somebody required could share) however few items is required resolution.
1.(Major case) In this cnc C axis is unlimeted, however in case toolchaning that G79C is just rolling C back :( - that could have unpredicted movements and I should to split program in case C has long path.
And during homming procedure - that is great and doesn't metter how long C was just till sencor and thats all.
My question here - does anybody knows command for OSAI for G code for axis homing (G79 is not options as I mentioned above) or any other solution (exept C axis limits) how to not spin back all path for example for C 25000 :(
Or maybe some configuration in CNC - any ideas wellcome and will be cheked.
2.(minor case) Wind40 has 2 separate tables (Y & V) and I would like to use them as separate however faced with case when Y standalone - fine. if V standalone - Y has tiny movements and sometime faced with Y limits which is stop all program. During invetigation I found out that case in (TCP,1) - without TCP Y is not moving only V moveing however that ruine whole path :(.
In additional if V standalone center tool correction doesn't not apply as well even with TCP.
Please advice if you have any suggstion or ideas.
Thanks.
6/3/24       #2: OSAI conrol need help ...
Don't have my Biesse Arrows with OSAI 10 controls any more but if you google OSAI 10 manual you will find the programming manual online. Should be first suggestion.
I still have a few bits and pieces of posts kicking around maybe even including one that was done for pendulum processing. If you send me a DM I can send you what I have.
6/4/24       #3: OSAI conrol need help ...
Pavlo Member
First of all - thanks for responce.
Regading manuals - I have a lot - papare 15 rev. , 17-18 rev in PDF. Maybe I missed something however I have not found answers on my questions yet.
And regarding DM. What is that? Sorry I didn't catch.
I can send everything what I have - post and other model
6/4/24       #4: OSAI conrol need help ...
DM is direct message
I looked and don't have any old stuff any more, at least nothing that will help.
Sorry and good luck.
6/5/24       #5: OSAI conrol need help ...
Pavlo Member
Thanks for the shot
6/6/24       #6: OSAI conrol need help ...
Karl Member
Website: https://virmer.com/
While the G79 command might not be suitable due to its behavior, you can look into creating a custom homing command or macro. In many CNC controllers, including OSAI, you can define macros that perform specific tasks. For instance, you might create a macro that checks the current position of the C-axis and then moves it to a safe position before performing a tool change.
You can explore if your OSAI controller allows for user-defined macros. Typically, these are defined in the controller's configuration files or through a setup interface. The macro could use conditional statements to decide the shortest path to move the C-axis to a homing position or directly to the sensor position without a full rollback.
6/7/24       #7: OSAI conrol need help ...
Pavlo Member
Hello Karl,
That is good suggestion and I will try to do this.
7/4/24       #8: OSAI conrol need help ...
John Member
Website: https://wattsan.com/
Karl, that's a solid approach. Creating a custom homing macro for the OSAI controller could definitely help manage the C-axis more efficiently and avoid unnecessary rollbacks.
    • Machinery Associates
    • Country Saw and Knife
