Subject: Re: Stuck tool changer on SCM Record 240
7/28/24
Benjamin Weston Member
I'm trying to help an ex-employer who's operator has recently passed away unexpectedly. They have no other operators on site for this machine, which is a SCM Record 240NTTE CNC router, continuous vacuum bed, 2 spindles (2.5 axis + 5-axis Prisma head) plus multi-drilling head, and it has been at least a decade since I used it myself.
I did get it running and cut a few parts, but then had to press the E-stop when the heads were moving into machining position because I'd left a board at the back of the machine that was a collision hazard for the gantry.
The machine was changing tools in spindle 1 as it was moving to start position. The tool that was in the spindle is now in the tool changer, the spindle is empty and the tool changer is in the correct position under the spindle for the next tool.
I have 2 errors;
PLC55: NEED REFERENCE TOOL CHANGER 2
PLC54: NEED REFERENCE TOOL CHANGER 1
Does anybody know the procedure for manually changing tools, manually moving the tool changer back to it's home position, or to reset the tool changers?
7/31/24       #3: Stuck tool changer on SCM Record 24 ...
rozliczae Member
To address the PLC55 and PLC54 errors on your SCM Record 240NTTE CNC router, start by power cycling the machine to reset minor errors. Then, use the manual controls to move the tool changer to its home position and perform a reference or calibration procedure via the machine’s control interface. Ensure there are no obstructions or jams and that the tool magazine is properly loaded. Consult the machine's manual for specific instructions or contact SCM support for detailed assistance if issues persist.
8/12/24       #4: Stuck tool changer on SCM Record 24 ...
HAIKol12 Member
Website: https://preisemenu.de/
To manually reset the tool changers on the SCM Record 240NTTE, you'll need to reference both tool changers via the machine’s control panel. Consult the machine's manual for exact steps.
