Subject: Re: Locating pin clamps
Locating pin clamps
8/27/24
Eric
Does anyone know where to get clamps that bolt to a locating pin for a CNC router. You bolt them to the pin and when the pins drop the clamp holds your part to the pod.
8/27/24       #2: Locating pin clamps ...
Dan Member
Biesse used to offer pop-up pins that could be used as clamps by adding a round disc secured by a bolt. When the pin lowered the part was clamped in place.
You could contact Biesse to see if the parts are available.
Note, that this option is not available on all pop-up locating pins. Our current machine cannot do this as the popup pin is solid and not threaded.
8/28/24       #3: Locating pin clamps ...
A good machine shop could drill and tap the pins.
9/4/24       #4: Locating pin clamps ...
Mike McClaran
Website: http://www.bettervacuumcups.com
What machine and what are you trying to hold. You can easily make the nylon donuts that screw to the top. I'm more curious as to why a vacuum cup will not work?
    • Machinery Associates
