Subject: Re: Busellato error code
12/6/18
Melissa Korthals Member
I have a Buselatto Jet 3006. I received an error:
Cycle Error n. 9003
I do not see this in any of my trouble shooting guides. Does anyone have any idea what this would be?
I can't stop the program that is running or set point.
12/6/18       #2: Busellato error code ...
Kevin Member
9003 should be linked, within the software, to a readable message. The message or language files may be missing some data. Try changing the language (CTRL+/) to Italian then restart and retest. Maybe it will show text that can be translated.
Is there a specific time when this message appears?
12/6/18       #3: Busellato error code ...
This is the second time I have seen this error code. I am not sure how I resolved it the first time. I did not write anything about it in my notes. I am running about 50 pieces using the same program over and over again. I had about 20 done when this came up.
12/7/18       #4: Busellato error code ...
Bruce H
My 3006 throws codes, drives me nuts. Sometimes I can re-boot and it will go away but remain on the screen as an error code. If I turn everything off and re-start usually it works. Sometimes it takes several tries. Always happens when I want/need to get something done.
I don't know what your error code is, I'd turn off the power and re-boot, set point and then try starting your program.
12/8/18       #5: Busellato error code ...
cabinetmaker
My rover 321 would throw a similar error due to overheat because of cycling the same part over and over. The cabinet was not air conditioned
12/8/18       #6: Busellato error code ...
Thank you for your responses.
Bruce I did just that. We turned it off for the night and it worked fine yesterday. No error codes.
9/25/24       #8: Busellato error code ...
Antonio Medina
Hello, I am working with a busellato jet 3006 model 5023
We have been having issues with the router spindle and now we’re unable to “set point” and do the “axis warmup” it’s throwing the code “digimainelman2 elm2 set point XYZ. What is it that i am doing wrong? How can it be fix.
    • Machinery Associates
