Subject: Re: PCD and plywood
PCD and plywood
11/1/24
Anyone out there cutting plywood with pcd?
If so, can you share speeds and feeds.
Hard to find info.
11/2/24       #2: PCD and plywood ...
BH Davis  Member
First of all I had to look up what a PCD was..........chuckle.
Polycrystalline diamond bits
Once that was done it appeared that the diamond bits are just adhered to a carbide slip so it seems the net result is a bit that would cut like a similar carbide bit.
So even though the longevity might be greatly enhanced I'd think you would use the same feeds and speeds as a comparable carbide tipped bit. No?
BH
    • Country Saw and Knife
    • Charles G.G. Schmidt Co.
