Subject: Re: CNC Error Handling
CNC Error Handling
11/19/24
Greta Member
Hi everyone! I'm new here, so if this has been asked and answered, I apologize.
Basically, I just want to know how your shops handle errors at the CNC. Does your operator flag someone down to fix it (who then flags someone else down, and someone else, until it finally makes it to an engineer) or do they fix it themselves?
OR, and this is the option I'm trying to find a good solution for, does your shop have an integrated system where, at the machine, they can submit an error report that gets sent to an engineer?
We use Homag machines, so they've got decent, easy to navigate monitors and touchscreen UX- I feel like we could have a tab open where if they get an error code they don't know what to do with, they can print screen and send it directly to the relevant people. I just don't know what software to use for that. Microsoft Teams, maybe?
11/19/24       #3: CNC Error Handling ...
Our machines are thankfully Fanuc, so there aren't a lot of errors. I can read and write G-code, so I understand most of the errors that come along. I teach the operators what they mean and how to fix them. I want them to be self sufficient and not walk off the floor to my office asking for help. Its really that simple. Takes time to encounter errors and then teach them about why they happen, but it usually works out well, as the senior operator can then show the others.
11/19/24       #4: CNC Error Handling ...
Greta Member
Mike,
We don't have a ton of errors, per se. Usually it's a one-off issue in programming that an engineer can resolve in a few minutes. The longest part is them walking off the shop floor to let someone know. If I could reduce that, we'd have a much smoother operation when it came to custom programs.
Our biggest culprit is in the nested base CNC because every part that goes through there is basically unique to a project, so there's more room for error on the programming side. We're always improving on the engineering side to reduce errors from the start, but we're human.
WoodWOP is nice, and makes for a really easy troubleshooting process, but the shop guys are a little tech-shy and no matter how much I try to teach them and empower them with their own solutions, they'd just rather we do it. We're working with them, but in the meantime, I need to cut out the response time to problems.
11/20/24       #5: CNC Error Handling ...
Well, my operators in the shop all get programming training by me before they get too much time in on the machine. If I made an error, I want them to be able to fix it quickly and move on. If they have a set up issue, which is almost always the reason for a problem, they should be able to just grab the part they need re-run and output just that before moving on. Once the guys get confident in their abilities, you rarely hear from them again. The main thing is I want them to have the knowledge and the ability to handle 2d parts and nests. I don't expect them to program aggregates or toolpath surfaces or solids, but one day I will train my replacement to do just that.
11/23/24       #6: CNC Error Handling ...
Derrek
It’s interesting, I’ve had 4 CNC, 2 Biesse and 2 Anderson’s and is what frustrates me is lack of documentation for issues like this. You get an error but no list of what that error is, especially common ones.
We created a document on the CNC computer that we could put an error code and what/how to resolve it. On bigger issues I created videos that we can refer back to and throw them up on you tube with a link to them on machine with QR code. Video below is from 4 years ago and we no longer have this machine
Biesse X Axis alignment
    • Machinery Associates
