Subject: Re: 2007 Anderson Selex Pal Computer Support Arm
11/22/24
Bobby Member
I bought a used 2007 Anderson Selex Pal and it's missing the arm that supports the control panel/computer monitor. I plan to make my own arm rather than buy one from Anderson.
Is there a current owner who can measure the distance between the mounting hinge pin and the center axis of the control panel table. Then I need the dimension of the height of the arm elevation from the mounting hinge to the control panel mount or the total height from the ground to the top of the control panel.
See the attached picture.
Anderson_Selex_Pal_Support_Arm.pdf
11/23/24       #3: 2007 Anderson Selex Pal Computer Su ...
Justin Hoover
Hi.Ours is a 2014, I'm pretty sure they are the same. It is 39.5 to top of arm and 45.5 to top of control panel.
11/23/24       #4: 2007 Anderson Selex Pal Computer Su ...
Bobby
Justin,
What's the distance between the hinge axis and the control panel axis?
11/23/24       #5: 2007 Anderson Selex Pal Computer Su ...
Justin Hoover Member
40 inches.
    • Machinery Associates
