Subject: Re: ABCD-Mambo 500/Hicam2- Help
12/18/24
Richard Terry
Website: http://www.advancedwoodsolutions.com
Hello,
I have a customer who purchased a used ABCD-Mambo 5000, it has an OSAI control, that also uses a Hicam2 interface. There's very limited information about them online, and the support from Italy, is not ideal.
He's having trouble whenever he tries to measure a tool, or execute a program. The CNC moves into position, then activates the air cylinder for the router to decsend, then immediately gives a Z axis positive limit error.
There are some variables called in the macro for the tool measure, and at the start of the program, I suspect that there are some user variables that are not correct but I'm struggling to find them.
I know this is a long shot, but any help or information would be very welcome.
Thank you!
12/19/24       #2: ABCD-Mambo 500/Hicam2- Help ...
OSAI 10?
I once found a programming manual via google.
12/19/24       #3: ABCD-Mambo 500/Hicam2- Help ...
Richard Terry
Thanks Dropout. I do have a programming manual, the issue is that the Tool measure macros reference H variables, that appear to be user controlled, but there's no description of what each variable stands for. In the variable table that I can find, all the values are zero. Apparently a previous attempt at getting things running with the support from Italy led to everything being reinstalled but it seems like things went sideways somewhere. I'll try and post a sample macro so you can get a better idea of what I'm on about.
12/20/24       #4: ABCD-Mambo 500/Hicam2- Help ...
There is an OSAI office in the US somewhere.
If I recall correctly this data is always stored somewhere - just need to find it.
I had a couple of Biesse with that control that lost all data due to a battery failure while not under power and we were able to restore everything from the control.
Does it home?
I wouldn't use the tool measuring since there are times when you lie anyway.
Do you have the full operation manual?
12/21/24       #5: ABCD-Mambo 500/Hicam2- Help ...
Jim Anderson
I would check to see if there is a sensor on the air cylinder that is out of position and not activated properly when the cylinder is lowered generating an out of position error.
12/24/24       #6: ABCD-Mambo 500/Hicam2- Help ...
Richard Terry
Website: http://advancedwoodsolutions.com/
Thanks guys. I will look at the air cylinder sensor, but I suspect that's not the issue, it will successfully perform a tool change whenever it's asked to, just not measure a tool, or begin cutting.
I've linked a sample program (created by the previous owners) and a macro. You'll need to change the extension from pdf back to txt, in order to view them.
davide.pdf
P1M18.pdf
1/14/25       #7: ABCD-Mambo 500/Hicam2- Help ...
Richard Terry
I know it's been awhile but I have got a little further with this. After adjusting the origins I am now able to get the CNC to execute G-code files. However I still have some problems. I have decided to abandon the onboard CAD/CAM software as it generates files with syntax errors. The main issue I am facing is that the CNC goes into an error whenever a T command is executed, either through the G code, or MDI. The OSAI control displays the following error:
Error 23/401- Process :01
New Tool Request Failed
in the HICAM2 window it displays a similar error:
99-152 Error T programmed process
This seems to hang up at around this point in the macro (I do have the macro if that is useful)
#PMT=0 ; Change from T like macro to normal PLC function
T(HI)
#PMT=1 ; Come back to T like macro
#(DLY,1);
Any Ideas?
1/14/25       #8: ABCD-Mambo 500/Hicam2- Help ...
Been a long time, but isn't DLY delay?
Don't have my books any more.
1/14/25       #9: ABCD-Mambo 500/Hicam2- Help ...
Richard Terry
You are correct DLY is a delay code. I think it maybe be hanging up on the line or 2 before, but this is what's displayed in the windows. It don't think it gives a line number, unfortunately.
1/17/25       #10: ABCD-Mambo 500/Hicam2- Help ...
Richard Terry
I've uploaded a screenshot. I'm wondering if it has something to do with CNC not knowing that there is a tool in the spindle. I have tries removing the tool and then intiating a T command, the result is the same. I can't see any way in which to tell the CNC what tool is actually in the spindle
    • Machinery Associates
