Subject: Re: Vertical router
Vertical router
5/17/25
Mark
Are any of the vertical routers that either Biesse, Homag, or Holz-Her make capable of machining all 4 edges of a panel with a tool 105mm in diameter?
I'm going to start looking at their websites, but not sure they will have that spec listed. Hoping someone who is running will have an answer for me.
Thanks in advance.
Mark
5/26/25       #2: Vertical router ...
NeonVortex Member
Vertical routers produced by manufacturers such as Biesse, Homag, and Holz-Her are typically versatile, capable of machining panels from various angles. However, machining all four edges of a panel with a 105mm diameter tool may pose challenges, depending on the tool size and accessibility. To determine if they can accommodate this tool size and effectively machine all four edges of a panel, specific specifications and capabilities of the vertical routers offered by these manufacturers need to be checked. Factors such as the maximum supported tool diameter, tool accessibility, available spindle options, and overall machine design will impact their ability to perform this task.
    • Machinery Associates
