Subject: Re: Drilling at an Angle
6/13/25
harry perry Member
I know it's a longshot, but anyone have any info on how to get a 5-axis machine to drill at an angle. I'm not even sure it would be called "Drilling" because Drilling pertains to the drill block. It's more like just getting a 3/16" bit to drop in at an angle. I can angle the spindle, but I can't figure out how to tell the spindle to approach at an angle vs just dropping straight down.
I basically need to make a 5mm hole at a 10 degree angle. If anyone has a snippet of code, regardless of machine or controller, that'd be a great place for me to start!
6/15/25       #2: Drilling at an Angle ...
I did a job recently drilling with an aggregate in a 4 axis machine at 15°. What are you programming with? I used Alphacam.
6/17/25       #3: Drilling at an Angle ...
Seems you lost interest in your project. I thought I had this on my YouTube channel, but had to upload it.
https://www.youtube.com/watch?v=k6g_bYxJqAQ
6/17/25       #4: Drilling at an Angle ...
Bob Holloway  Member
Website: advantagewoodwork.com
For this using are Campus Hops software you first need to use a free view and rotate the XYZ plane. Then you can make the drilling at an angle. I imagine each software has a method. For us it’s manipulating the view. Good luck!
6/18/25       #5: Drilling at an Angle ...
harryperry
Thanks for the responses Mike and Bob.
I did end up trying the Free View method, which is fantastic for operations on an angle, but after looking things over, I realized that all I needed to do was to use a horizontal drilling macro vs a vertical drilling macro.
I hadn’t even considered that because I assumed horizontal drilling was only for edge work.
Bob, how long have you been using HOPs?
    • Lunyee Industries Development
      CNC Routers, Laser Engravers and Accessories
