Subject: Re: Drilling at an Angle
6/13/25
harry perry Member
I know it's a longshot, but anyone have any info on how to get a 5-axis machine to drill at an angle. I'm not even sure it would be called "Drilling" because Drilling pertains to the drill block. It's more like just getting a 3/16" bit to drop in at an angle. I can angle the spindle, but I can't figure out how to tell the spindle to approach at an angle vs just dropping straight down.
I basically need to make a 5mm hole at a 10 degree angle. If anyone has a snippet of code, regardless of machine or controller, that'd be a great place for me to start!
6/15/25       #2: Drilling at an Angle ...
I did a job recently drilling with an aggregate in a 4 axis machine at 15°. What are you programming with? I used Alphacam.
6/17/25       #3: Drilling at an Angle ...
Seems you lost interest in your project. I thought I had this on my YouTube channel, but had to upload it.
https://www.youtube.com/watch?v=k6g_bYxJqAQ
6/17/25       #4: Drilling at an Angle ...
Bob Holloway  Member
Website: advantagewoodwork.com
For this using are Campus Hops software you first need to use a free view and rotate the XYZ plane. Then you can make the drilling at an angle. I imagine each software has a method. For us it’s manipulating the view. Good luck!
6/18/25       #5: Drilling at an Angle ...
harryperry
Thanks for the responses Mike and Bob.
I did end up trying the Free View method, which is fantastic for operations on an angle, but after looking things over, I realized that all I needed to do was to use a horizontal drilling macro vs a vertical drilling macro.
I hadn’t even considered that because I assumed horizontal drilling was only for edge work.
Bob, how long have you been using HOPs?
6/19/25       #6: Drilling at an Angle ...
Harry, are you going to let us know how you're doing on your panel times in your other thread, or are you just gonna blue ball us?
6/19/25       #7: Drilling at an Angle ...
Bob Holloway  Member
Harry,
We’ve been using hops for about 6-7 months and it’s been easy to use and understand. We like how flexible it is to rearrange steps which makes processing more efficient at the machine. We like it. I’ve been away from CNC and related software for about 15 years and software has become much easier to use in that time. Glad you were able to find a solution. The horizontal boring does not always work for us and we find the free view simpler to use, especially for series of hole patterns.
6/20/25       #8: Drilling at an Angle ...
Harry Perry
Bob, we started about 4 months ago and it’s our first forray into the cnc world. I was pretty amazed how quickly we were making things in HOPs and aCADemy. I have been messing with Free View and it’s actually a pretty powerful tool.
Super frustrating how little there is in the way of videos / tutorials online for NC Hops though. Not to mention every other error message that comes up is in German.
Karl, for now I kind of just shrug and shake my head at our processing speeds. 47 minutes for a sheet of UDF edge profile drawer fronts, 22 minutes for a sheet of UDF raised panel doors. But at least our times for simple melamine cabinets and slab doors are down.
6/25/25       #9: Drilling at an Angle ...
Saya lmm  Member
Website: https://lmmcementedcarbide.com/
Thanks for sharing, Harry
7/1/25       #10: Drilling at an Angle ...
Mark
What kind or type of drill can be used to drill at an angle without wandering upon entrance of the wood?
I just got a 5 axis router and I have a job coming up that requires a 10 degree angle into edge grain. I'm not sure a brad point won't wander.
Any advice would be appreciated.
Mark
7/2/25       #11: Drilling at an Angle ...
I already posted this, but it didn't show. In my video and production I drilled hundreds of holes with an 1/8" diameter 30° upshear spiral router bit. did well without wandering. I used a pecking cycle to get it done. That pulled the chips out and made clean holes. Good luck. Mine was 15°.
7/2/25       #12: Drilling at an Angle ...
Mark
Mike,
Thank you very much, I never considered that.
I have enjoyed your YouTube videos, they have always given me food for thought.
Mark
7/2/25       #13: Drilling at an Angle ...
Mark,
My You Tube videos were only created to share with a couple of buddies and people I was training. Thats why there is no voices, just machine noise. Anyway, I'm glad others like seeing the odd stuff I do. I never post anything that is "run of the mill" stuff which is 95% of what we do. I think it is cool to show off possibilities that others may not have thought of.
    • Machinery Associates
