Subject: Re: rake bar
rake bar
6/25/25
Mark Hekkers Member
My SCM Pratix N12 has a rake bar that pivots out of the table but will not advance the parts. I cannot move the bar with the appropriate commands in the ISO screen. So, it won't retract back into the table either. Does anyone have any ideas?
9/9/25       #2: rake bar ...
RODNEY BLACKERBY Member
We have have a pratix n15 with the same setup, check the cable under the table also some micro switch's there are 2 of them if Its not coming in contact with them could be your problem, could be a cylinder or air issue or valve sticking. I might be wrong but I think its controlled by the control logic, If you look under the machine most likely where your air line connect to the machine there are a series of valves that control most of the pneumatics on the machine. pretty simple and straight forward system but we have had problems with ours sticking from debris getting stuck in there and sometimes machine will not let you load the next sheet. hope this helps
    • Machinery Associates
    • Country Saw and Knife
