Subject: Re: Weeke issue with tool changer
9/15/26
Tim Sikorski
Hello, I have an issue with my Weeke Optimat venture 5. The tool changer blows a fuse when I try to index it. I suspected the 24v index motor, but operated it with a separate power supply and it worked fine. Suspected the cable from that J-box on back side to motor, ran 2 new wires, and still blew fuse. The TC lid opens up fine, but as soon as you try to index it, fuse blows.Anyone else have this issue in the past?
9/15/26       #3: Weeke issue with tool changer ...
Mack McPherson Member
Purchase and replace the ice cube relays from Stiles. You also must change the mounting block with them. They come as a set. Keep an extra set on hand.
30-282-54331
9/15/26       #4: Weeke issue with tool changer ...
Tim Sikorski
I will try that now. I have some on hand.
    • Country Saw and Knife
