Aborted X left axis switch low error
8/30/14
Dennis Trump Member
Website: http://www.thefinishingtouchcncrouting.com
I had been running a very simple profile job when I needed to go out of town for a few days. Everything was shut down and left as it was so I could start back up when I returned. When I began again the gantry moved into position,the z axis moved to just above the work piece and stopped.
I'm running WinCNC Version 2.403 with Vectric Aspire. When the machine stopped WinCNC had the error on screen that the the left low axis switch aborted. After that my x axis wouldn't move. All other axis would still move as expected manually or automatically except to the left. I need some help figuring this out. I even tried reloading the original software with the machine parameters on it which had no effect. Any ideas for a fix?
8/30/14       #2: Aborted X left axis switch low erro ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
Dennis,
One of the limit switches mounted on the X-Axis is either switched or not sending signal to the input. The "low" means that it is missing signal. The signal should be "high" or on. So right now the machine thinks that the X axis is all the way at the end of one of the sides. It may not be physically there, but the switch is not sending the signal saying it is clear. Try activating the switch a few times, it could be it got a little dirty inside.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@themachinewarehouse.com
8/31/14       #3: Aborted X left axis switch low erro ...
james mcgrew Member
Website: http://mcgrewwoodwork.com
open the Input screen with the machine and software on activate the switch with your finger and see if indicator light goes on or off. If not then switch is the culprit.
this is one of two reasons I get low axis errors the other it the machine thinks it is trying to machine below the set parameter
