Need help fixing PC for drill and dowel machine
9/10/14
Ryan Member
I need help. I have a 1994 ACCU SYSTEMS bore and dowel machine. The PC motherboard just gave out on me and I can't find a replacement PC with the correct fittings. We checked with the manufacturer but they don't have a solution for replacing the PC. I'm told we need a motherboard with a long icis insert so that I can translate to the machine with a 50 and 60 pin cable.
Does anyone know of a source to replace old PC parts or entire pc units?
9/10/14       #2: Need help fixing PC for drill and d ...
jerry Member
See if a pci to isa card will work for you.
9/11/14       #3: Need help fixing PC for drill and d ...
Luke
Website: http://www.calwoodinc.com
Ryan,
We have been proactively preparing for a failure on our Accusystems machine. Is your PC made by Advantech? Our machine is about 8 years old. We had a fan go out and I was able to find a source for that. Send me a picture of your PC with specs and I'll see if we can help.
